All the time or just when you start it?
Bad valve seals................. Bad ring seal...................... How much oil does it use?
Ontario Rodders |
burning oil. most likely blow-by from your piston rings, or maybe from old worn out valve seals.
yup, you're going to have to rebuild it, the rings are shot. It will give you a chance to put some fun parts in it. Nobody wants to hear that their engine is shot, but you can rebuild one a lot easier and a lot cheaper than you might think. Worry not!
K |
a guesstimate.....
this applies only if you all ready have the necessary tools......
machine work- @ $ 300- $400 (hot tank, bore 8 holes, valve job on heads, new cam bearings installed.) rebuild kit, northern autoparts @ $150 allready rebuilt, ready to swap out motor- @ $650 on up..... |
Variables include machinework and performance parts. For a mild rebuild that you do yourself and minimal machine work, I'll bet you could have it back together for... 5-700 dollars? A lot of it will depend upon if you have to buy new pistons and get it bored out. That is really the most expensive part. I think you can get a rebuild kit through summit for pretty cheap, about 2-300 bucks.
K |
check it out!
Before you go pulling an engine to rebuild it,based on "blue smoke".......verify that ATF is not being pulled into the intake via the vac modulator IF you have an auto trans! It seems to me that a cylinder pressure check would be in order prior to writing off the engine.
most definately do a compression test first.
