Blue smoke at idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2006, 08:46 AM
Blue smoke at idle
If I let my truck idle for a few seconds in or out of gear and then pop the throttle I get a puff of blue smoke. Put it in neutral and hold it at 1500 rpm and there is no smoke coming from the pipes. It is definately oil, keeps getting lower on the dipstick. Thinking possibly three things, that my valve stem seals are leaking(four of my eight plugs are wet when removed after the engine was running), or that my carb needs adjusted, or it could be sucking up oil through the PCV valve. Any thoughts?
Old 06-17-2006, 09:28 AM
What's the mileage on this motor? Is the valve cover baffle in place where the PCV is installed? Sounds like when the manifold vacuum is higher it's pulling oil into the intake. How about leaky intake gaskets allowing oil to be drawn into the intake ports. A test with a vacuum gauge might tell the story. Check the link below.
http://www.secondchancegarage.com/public/186.cfm
Old 06-17-2006, 09:46 AM
Mileage is about 3500 miles. It's a 355 that I recently rebuilt. Your comment about the valve cover baffles could very well be my problem. The valve covers I bought have one hole in each cover. If your looking at the engine from the grill I have the PCV valve in the back left hole and the little air cleaner lookin thing in the front right. I fill the oil through the front right and it has a baffle cause it takes and hour to fill it with oil. Maybe the one in the back has no baffle? Also, I should get about 16" vaccum with this cam (268H comp) but can only seem to muster 10". Doesn't seem like I have as much power as I thought I would. Should have at least 300 hp but with 31" tires, a 2200 stall converter, 3.08 gears, and a th350 tranny I cannot spin the tires no matter what.
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
constant whitish blue smoke greg johnson Engine 3 07-06-2004 02:03 AM
blue smoke panhead65 Engine 11 01-04-2004 04:26 PM
Typical Chevy Blue Smoke? Kaylah Engine 15 08-19-2003 01:00 AM
chevy 350,rough idle when started and little smoke until warmed up IHAVECHEVYPARTS Engine 2 11-18-2002 02:29 AM
