bluecatford - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2006, 10:02 PM
bluecatford
HELP with 351ci or 5.8 for the younger generation. 1994 Bronco. can I change the cam with the stock computer? or will it screw something up ? or will it attempt to make it run stock?
HEADERS?? are they a help? or mainly just throwing $$ away?
duel Exhaust ???
how much can a person do to these computer controlled vehicles?? I'm from the old school carbs, cams, intakes, heads,.. I'm LOST
Old 05-28-2006, 05:09 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
CompCams can recommend a cam that will work with the stock speed density system. Exhaust and cold air help a lot.
Just got rid of a 95 Bronco W 4wd Eddie Baurer. Mine had the one ton truck 4wd AOD trans from the factory...... $ 2000 rebuilt...
Don't expect gas mileage to be any good. 16 maybe at 55 mph.
Beyond dual exhaust with Walker Dynomax Super Turbos, I think you are wasting your money. It won't be much faster nor get more mileage. Good luck.
bluecatford bluecatford Introduce Yourself 1 05-27-2006 10:23 AM
