Blueprints muscle series 23* heads SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2012, 07:16 PM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
Has anyone seen these yet? Right there in my summit book. There actually Looking good. Heres the specs. Aluminum, 195 intake runners, 75 cc exhaust. 64cc combustion chamber, 2.02 intakes 1.60 exhaust valves. Look like some serious power, better yet they start out fully assembled pair for $895. Hydraulic roller or for some flat tappet cams, valve spring height, open/closed lbs. and springs OD not specified. Just putting this out there, any guy wanting some serious SBC street heads for cheap, larger CR, blueprints got it.
Old 02-17-2012, 11:34 AM
techinspector1's Avatar
Wiki Edits: 326
I have emailed Summit and asked for the flow numbers @28" water.
Old 02-18-2012, 04:16 PM
mr mighty mouse
Once you have the flow data, could you share?
Has Blueprint done this before with cylinder heads?
Old 02-18-2012, 08:19 PM
Originally Posted by Dru from Blueprint
The castings are made over seas, like some others. We assemble them ourselves in the in USA. They are not Pro-Comp, they're ours. The flow numbers I'm posting here are from our own bench, which uses Audie Technology software and sensors. I would point out that our bench is calibrated with plates, when we test other brands of heads most of the very good higher end brands match up with what the companies that make them claim, so it compares well. On our Bench, these heads do not out flow all the competitors, the high end brands flow better, but we flow better than some of the lower end brands. As of now these are only available with an as cast port and chamber. We have used a lot of these heads on engines and have not had any problems with the castings. The valves we use are made in the US and South America, pretty much the same valves that just about everyone uses. Same deal with springs and retainers, pretty standard items. I donít have any cutaway pics, but I would not characterize these heads as having extra thick decks for big time power adders, but they are very good normally aspirated.
At 28 inches H2O
Exhaust Intake
.100 54.9 69.9
.200 101.6 128.9
.300 141.6 178.1
.400 156.5 213.3
.500 167.9 245.1
.600 171.2 242.1
As posted last summer on Chevelle Tech.
I would do a Google search for more info on BluePrint and their parts.
Old 02-19-2012, 12:54 PM
Wiki Edits: 326
Blueprint...(rounded to the closest whole number)
0.100" valve lift, 70 int., 55 exh.
0.200" 129, 102
0.300" 178, 142
0.400" 213, 157
0.500" 245, 168
0.600" 242, 171
Let's compare them to the L31 heads....
0.100" valve lift, 70 int., 48 exh.
0.200" 139, 101
0.300" 190, 121
0.400" 227, 140
0.500" 239, 147
0.600" not published
Old 02-19-2012, 05:49 PM
You get what you pay for. Those would be a solid candidate (power-wise) for a street cruiser that occasionally sees the strip. A 355 or a 383 with correct parts would make decent power but nothing extraordinary. Maybe 375-400horse out of a 355 or 400-425ish out of a 383 with a good cam, performer rpm intake and 750 carb. You'd need a really big cam, a victor style intake and an 850 to get up near 500. For $895 they seem like a good deal, but you might have to swap springs for whatever camshaft you are running. You NEVER buy springs based solely on "IF" they can handle the amount of lift. It cracks me up when I see heads sold with springs that say "Good to .600" lift". Oh yeah? Slip a stock eliminator cam in there and see what happens, lol. Don't get me wrong, it's cheaper to buy heads fully assembled but buy them right from the manufacturer who can install the EXACT spring you need for your application. If I was building a total budget build I would consider these heads but if I were to be building something that may see some strip action i'd spend $300-$500 more and get something from AFR, Dart, TFS, etc, that flows near 300cfm with a similar sized port. I really like the new 21 degree TFS head btw.
Old 02-20-2012, 06:42 PM
Landshark928's Avatar
FrankenPorsche
Is it a USA made head or just a re-badged ProComp? Flow numbers are real close to the gen3 PC 195s.
Bryce at Dr.J has a killer 220CNC head from a PC casting.
Old 06-10-2017, 10:18 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Just a note on this, if they are cast over seas they wont be their design for long..I'm sure by know the chinese have copied every thing and are casting these in no name for for everyone and their brother.
ls series heads on sbc? ThorImmortal11 Engine 8 01-17-2010 08:12 PM
How do i identify between 2 series and 3 series gears? strokey Transmission - Rearend 4 04-14-2008 10:22 PM
BBC Heads. Series vs Parallel Cooling. Check out these Pics leejoy Engine 10 11-09-2007 03:49 PM
chev truck 3100 series vs 1300 series? In_Style Hotrodding Basics 14 07-17-2005 06:51 AM
