#1
bmw 318is,E36, 1998 model
Originally Posted by bomba33g
I have checked the alternator and battery voltage and found it to be fine at 14volts while the engine is running. The alternator seems to be charging fine but the car still cuts off. I have also changed the fuel pump.The car cuts off even while the engine is just in idle mode and while running.It also gives out a shooting/banging sound like a gun going off at the exhaust pipe at the back when it is running. A backfire through the exhaust is normally a sign of being lean. Since you replaced the fuel pump, did you replace the filter? There may be more than one filter as well. A clogged filter can cause intermittent problems, though normally not at idle. Also double check all of you electrical connections to and from the ECU and coil. Pull one plug wire at a time and double check for a strong spark. The distributor may need help. There are many things that could cause you problem, you just have to eliminate one at a time. Register now (free) or login to remove ads |
| Thread Tools | Search this Thread |
| Similar Threads for: "bmw 318is,E36, 1998 model" | ||||
| BMW E36, 318is 1998 model | bomba33g | Hotrodding Basics | 5 | 01-04-2012 05:49 PM |
| BMW 318is cutting off | gombera | Engine | 0 | 12-13-2011 06:22 AM |
| 1996 BMW 318is/328is, any feedback?? | jordan2011 | Engine | 2 | 01-27-2008 06:23 PM |
| early model vs. late model 350 blocks | quincysmith | Engine | 11 | 08-15-2007 11:12 AM |
| Late model GM Steering Column for Model A | Woody31coupe | Suspension - Brakes - Steering | 3 | 12-31-2005 05:55 AM |
