boat engine for truck. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-11-2012, 12:39 AM
The propeller thrust is not going to go around a corner, through two sets of bevel gears in an outdrive. It is also not going to go through a V-drive.
My Ski Nautique has a 1.23 to 1 reduction transmission, the thrust does not make it past the driven gear in that transmission.
I would think that most "direct drive transmissions", even ones that have the propeller shaft in line with the crankshaft have a thrust bearing somewhere in them.
It is possible that some design may apply propeller thrust directly to the thrust bearing on the crankshaft, but I cannot think the thrust bearing on the crankshaft would last very long in that application.
  #17 (permalink)
Old 11-11-2012, 08:53 AM
Hey DanielC, What year Nautique do you have? Been working at the company that built your drivetrain for 15 years.
  #18 (permalink)
Old 11-11-2012, 10:57 AM
Troutman,
I have a 1997 Ski Nautique, with 2443.3 hours. It has the Ford GT-40 engine, and is still running great. The hull was built in October of 1996.
So, you work for PCM?
  #19 (permalink)
Old 11-11-2012, 04:38 PM
Yes, that GT-40 is an awesome engine w/ plenty of torque. I worked in the warranty for my first 9 years, and now i build subassemblies such as motor mounts, fuel control cells, potentiometers for drive by throttle and catalytic converters for our exhaust systems.
Boat engine help handymann3 Engine 6 07-05-2010 03:07 PM
Street Engine w/ Boat Cam BG383 Engine 4 08-05-2009 10:52 PM
Older Caddy Engine (Boat Anchor?) New2theart Hotrodding Basics 23 01-08-2009 03:25 PM
Corvette engine in boat KennyNova Engine 7 08-14-2007 07:11 PM
cool 100 ++ MPH boat blown boat video Infomaniac Engine 12 11-24-2003 09:08 AM
