-   -   are boats considered hotrods, here? (http://www.hotrodders.com/forum/boats-considered-hotrods-here-230646.html)
h0trod 03-12-2013 09:44 PM
can anyone give me any further insight on this boat?
i have it regestered as a hallet, but many people dont think so...
http://i109.photobucket.com/albums/n...nCruise287.jpg
Joe G 03-12-2013 10:46 PM
Nice boat.
I'm no expert, but if it's a '72 or newer, it should have a hull ID code somewhere on the transom. If the first three digits of the ID code are 'BAR' it's a Hallett. (link 1) (link 2)
Hope this helps...:thumbup:
MARTINSR 03-12-2013 11:02 PM
Daaaaaaamn that is a hot rod!
h0trod 03-13-2013 10:13 AM
Originally Posted by Joe G (Post 1656271)
Nice boat.
shes a '66.
no hull numbers.
as you can tell by this picture, its not a norml v-drive.
the box is wayyyyy foward.
http://i109.photobucket.com/albums/n.../IMG_06691.jpg
fwinter01 03-13-2013 10:21 AM
looks like a witchcraft
body lines it appears to be a witchcraft from southern cal, fontanna area
geezer69 03-13-2013 10:37 AM
yep, its a hot rod.
s-10again! 03-13-2013 10:42 AM
that is definately a hotrod. if it had wet exhaust i would call it a speed boat. dry exhaust can use any cam you want. proping is alot easier than gearing and stalling a rolling vehicle too. how about some specs on that engine sir?
h0trod 03-13-2013 11:06 AM
pontiac 354, 030 over, 2.11 and 1.66 valves, 9.8:1 cr heads flow about 260 cfm. .488 lift cam, peformer rpm modified intake, with a spread bore holly 750 DP
13" 15 prop underdriven on the 10 degree cassel, dont know the percent of gears, i havnt goten in to the box yet.
im also working on a 383 small block'd 66 wesco 16 footer v-drive flatbottom
s-10again! 03-13-2013 11:08 AM
omg 16 footer
h0trod 03-13-2013 11:10 AM
shat and gat! :)
http://i109.photobucket.com/albums/n...nCruise283.jpg
lg1969 03-13-2013 11:28 AM
Hey HOtrod, That is not a Hot Rod. That is an ICBM flying just above water.
h0trod 03-13-2013 11:32 AM
Originally Posted by lg1969 (Post 1656424)
Hey HOtrod, That is not a Hot Rod. It's an ICBM flying just above water.
i like the way you think....
techron 03-14-2013 01:38 AM
Sorry, no offence, but that would not fly in the SF bay. Any V drive boat (especially a 16? footer is a calm lake boat) hitting waves in a fiberglass boat will destroy that V drive, in a fiberglass boat when hitting any waves have you ever seen the hull flex??? I have, they flex like crazy. Many years ago I ran a 21' deep V hull jet boat in the bay, 455 olds with a Berkley jet.
It took 2 years to make it bay worthy!!! I had to sort out everything, the first problem was with the body flex-the cable steering would short out the ignition switch and kill the engine. Spending the night out on the bay was no fun. Did it twice and hated it both times. The first time the engine died just at dusk. We floated along SF almost to the Gate and ended up just south of the san mateo bridge the next morning. The Tides are strong in the bay. The second time I knew what to do on the 21 deep V jet. Crawl into the bow and when the water hit my feet I would turn on the bilge pump.
Enough of that. Bought a 40' corsa with twin big blocks so I coluld cruise out in the pacific, the 2 engines never left me stranded again. Bought it in LA and piloted up to SF. That was also scary,
Richiehd 03-14-2013 07:00 AM
1 Attachment(s)
Well, as long as we are on the subject!!
S10xGN 03-14-2013 09:12 AM
First boat I've seen set up in a "left-side driver" configuration...
