are boats considered hotrods, here? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2013, 09:44 PM
if you beat my boat, well race
can anyone give me any further insight on this boat?
i have it regestered as a hallet, but many people dont think so...
Old 03-12-2013, 10:46 PM
Joe G's Avatar
Nice boat.
I'm no expert, but if it's a '72 or newer, it should have a hull ID code somewhere on the transom. If the first three digits of the ID code are 'BAR' it's a Hallett. (link 1) (link 2)
Hope this helps...
The Following User Says Thank You to Joe G For This Useful Post:
h0trod (03-13-2013)
Old 03-12-2013, 11:02 PM
Daaaaaaamn that is a hot rod!
The Following User Says Thank You to MARTINSR For This Useful Post:
h0trod (03-13-2013)
Old 03-13-2013, 10:13 AM
Originally Posted by Joe G View Post
Nice boat.
Hope this helps...
shes a '66.
no hull numbers.
as you can tell by this picture, its not a norml v-drive.
the box is wayyyyy foward.
Old 03-13-2013, 10:21 AM
looks like a witchcraft
body lines it appears to be a witchcraft from southern cal, fontanna area
Old 03-13-2013, 10:37 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
yep, its a hot rod.
Old 03-13-2013, 10:42 AM
that is definately a hotrod. if it had wet exhaust i would call it a speed boat. dry exhaust can use any cam you want. proping is alot easier than gearing and stalling a rolling vehicle too. how about some specs on that engine sir?
Old 03-13-2013, 11:06 AM
pontiac 354, 030 over, 2.11 and 1.66 valves, 9.8:1 cr heads flow about 260 cfm. .488 lift cam, peformer rpm modified intake, with a spread bore holly 750 DP
13" 15 prop underdriven on the 10 degree cassel, dont know the percent of gears, i havnt goten in to the box yet.
im also working on a 383 small block'd 66 wesco 16 footer v-drive flatbottom
Old 03-13-2013, 11:08 AM
omg 16 footer
Old 03-13-2013, 11:10 AM
shat and gat!
Old 03-13-2013, 11:28 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Hey HOtrod, That is not a Hot Rod. That is an ICBM flying just above water.
Old 03-13-2013, 11:32 AM
Originally Posted by lg1969 View Post
Hey HOtrod, That is not a Hot Rod. It's an ICBM flying just above water.
i like the way you think....
Old 03-14-2013, 01:38 AM
Sorry, no offence, but that would not fly in the SF bay. Any V drive boat (especially a 16? footer is a calm lake boat) hitting waves in a fiberglass boat will destroy that V drive, in a fiberglass boat when hitting any waves have you ever seen the hull flex??? I have, they flex like crazy. Many years ago I ran a 21' deep V hull jet boat in the bay, 455 olds with a Berkley jet.
It took 2 years to make it bay worthy!!! I had to sort out everything, the first problem was with the body flex-the cable steering would short out the ignition switch and kill the engine. Spending the night out on the bay was no fun. Did it twice and hated it both times. The first time the engine died just at dusk. We floated along SF almost to the Gate and ended up just south of the san mateo bridge the next morning. The Tides are strong in the bay. The second time I knew what to do on the 21 deep V jet. Crawl into the bow and when the water hit my feet I would turn on the bilge pump.
Enough of that. Bought a 40' corsa with twin big blocks so I coluld cruise out in the pacific, the 2 engines never left me stranded again. Bought it in LA and piloted up to SF. That was also scary,
Old 03-14-2013, 07:00 AM
Richiehd's Avatar
JS-70
Well, as long as we are on the subject!!
Old 03-14-2013, 09:12 AM
S10xGN's Avatar
Gotta love a turbo!
First boat I've seen set up in a "left-side driver" configuration...
would this be considered a good cam? 68sscamaro Engine 1 05-10-2009 05:20 AM
Is this considered vapor lock? Trumpet1 Engine 10 04-30-2009 07:30 AM
Hi Gang. Is this considered a Hotrod? Runnin'OnEmpty Introduce Yourself 4 09-14-2007 01:40 PM
boats handsome harv Introduce Yourself 3 11-09-2006 02:06 PM
options to be considered????? camaro420 Engine 1 12-01-2005 02:02 AM
