Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bobbin Winder on 111W?
Old 02-10-2010, 06:49 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
If you slip the bobbin onto the shaft and it sort of spins on there (not enough friction) you can spread the shaft with a screw driver. Mine loosened up on me after winding a few bobbins so I had to spread my a bit. Works good now.
Is that you problem or does it appear to be something else?
Always learning...and sharing what I've learned.
