-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Bobbin Winder on 111W? (http://www.hotrodders.com/forum/bobbin-winder-111w-172810.html)
Coodeville 02-10-2010 02:38 PM
Im following the book but the bobbin will not grab. Is it poosible I was given the wrong winder? Photo's will follow
cboy 02-10-2010 07:49 PM
If you slip the bobbin onto the shaft and it sort of spins on there (not enough friction) you can spread the shaft with a screw driver. Mine loosened up on me after winding a few bobbins so I had to spread my a bit. Works good now.
Is that you problem or does it appear to be something else?
Coodeville 02-10-2010 09:57 PM
Thanks for answering the question. Before I read your response, I took a good look at it and did just that. It works fine now. I was a real pain doing it by hand.
cboy 02-10-2010 10:14 PM
Glad you got it working.
