Bobbin Winder on 111W? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2010, 01:38 PM
Im following the book but the bobbin will not grab. Is it poosible I was given the wrong winder? Photo's will follow
Old 02-10-2010, 06:49 PM
cboy's Avatar
Last journal entry: Finished
If you slip the bobbin onto the shaft and it sort of spins on there (not enough friction) you can spread the shaft with a screw driver. Mine loosened up on me after winding a few bobbins so I had to spread my a bit. Works good now.
Is that you problem or does it appear to be something else?
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 02-10-2010, 08:57 PM
Thanks for answering the question. Before I read your response, I took a good look at it and did just that. It works fine now. I was a real pain doing it by hand.
Old 02-10-2010, 09:14 PM
cboy's Avatar
Glad you got it working.
