body bushing install - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2007, 02:30 PM
hello. its time for me to put some new body mount bushings on my 68 chevelle. i had a article awhile back on how to with a jack and 2x4 but lost it. can anyone help? thanks. i cant take the body off the frame completly. i'd also like to por the frame
Old 05-06-2007, 07:56 AM
Vortech 4.3's Avatar
jack of all trades
take all the body bolts out. then, on the "opposite" side of where you will be working, install a few a couple of turns in. this will keep the body from shifting.
find a solid area of the body where you can jack, use the wood to keep the jack from rolling a seem and to help distribute the weight. then jack the body just enough to get the old out and the new in.
to POR. put wood next to where the mounts go, to raise the body all around. some longer body bolts would be a good idea = to keep the body from shifting. POR, move the wood over, POR that spot. new mounts, then finished.
your only going to be raising the body a couple of inches. but still look to see if anything will hang up from raising it.
Old 05-06-2007, 02:25 PM
body bushings
thanks for the response. thats even better than the instructions that i found online..thanks again...smokey
Old 05-06-2007, 06:48 PM
jack of all trades
your welcome.
one more thing. somehow (you have to figue that out) put some alignment markings, so the body sets back down in the same place (i could shift my body around a little). this is assuming that it was aligned in the first place.
Old 05-07-2007, 11:17 AM
thanks..i get lifting the body on one side, but how many loose bolts should i run on the other side? think a few is enough to keep the body from shifting?
Old 05-07-2007, 06:56 PM
jack of all trades
2 would be fine. even just 1 "well placed" would work. but don't take a chance, use at least 2.
Body - Exterior "Tips of the Day" Jon Body - Exterior 11 09-07-2007 11:29 AM
First Body and frame split. Thoughts on "least damage" schnitz Body - Exterior 9 05-06-2007 11:22 PM
Free Body Diagrams BillyShope Suspension - Brakes - Steering 4 04-27-2007 05:40 AM
Body bushing advice, 70 Nova baddbob Body - Exterior 4 12-05-2005 06:30 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
