body bushings 56 chev. truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2002, 08:04 AM
bullheimer's Avatar
NEVER use credit cards!
Post body bushings 56 chev. truck
stock the bushings are like half inch thick under the cab and under the radiator support was like a rag joint, about 1/4 inch or so. now i have a 3" poly one in rear of cab, and about 5/16" poly under the front of cab and like 1/8" poly under radiator support bracket. Going over rough roads my truck is quite as a mouse. even so i'm thinking of increasing all of them at least 1/2". i might have to lengthen my clutch pedal rod but maybe not and wont have to do anything to my steering shaft. should i change it or leave things alone. i have to have the height finalized to mount my front bumper. i'm not changing the box mounts.
