body bushings on 68 firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2004, 09:20 PM
smily1's Avatar
pontiac nut
Hi,
I posted this on another section...just dont know where this question fits so I apologize in advance.
I did a search and found little...I hope this means its not all that hard.
I have factory replacement bushings for the subframe. Is there any special way to do this? there are 3 for each side. I assume radiator support and 2 on the lower frame. Is it best to loosen one side at a time (loosening all three) and replace? Is there any other bolts that need to be removed to replace these? Any tip/tricks??
Thanks for your help folks.
rob
Old 05-26-2004, 01:07 AM
Pony's Avatar
I think you've got it right. I'd loose the three on one side, do each one, tighten them all up and do the other side the same way. I've never done a Firebird so I can't say what if anything else needs to be done. Good Luck..
Old 05-26-2004, 06:08 PM
smily1's Avatar
pontiac nut
Thanks for the info Pony.
It was rather easy and went pretty fast. Wow. After 36 years those body bushings literaly crumbled off the car when I tried to remove them. It will be interesting to see if I can notice a diference in ride quality.
rob
