body bushings????????????????HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2009, 11:17 AM
i got a 81 parisienne coupe... and changed my bushings and put polyurethanes and they suck the car drives like a civic.. every bump on the road i feel but no complaints on handling.. nways i wanna go back to rubber mounts cuz comfort is a priority for me compared to handling (its a cruiser not a ricer) my question is
where can i get the rubber bushings (already went to gm i just want other options) also will g-body bushings work on a b-body... since the kit i got from energy suspension was for a g-body (it was listed as the same for a b-body)
thanks
Old 07-31-2009, 12:31 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Re Cycle yard if you have already thrown out the old ones
sam
Old 07-31-2009, 01:13 PM
sam
the old ones were finished and some cases the bushing fell off
Old 07-31-2009, 01:50 PM
Wiki Edits: 3
H'mmmmm check with some of the parts stores then..those in stock form can be hard to come by except from dealer..Year One may have some or maybe even JC Whitney..Other than that dunno..
Sam
Old 07-31-2009, 07:50 PM
ericnova72's Avatar
More for Less Racer
thanks
This is all the info you need right in front of you.... Since the G and B-body bushings are INTERCHANGEABLE if made of polyurethane, that means that they would be interchangeable no matter what material they are made out of-- Rubber, plastic, aluminum, steel, Delrin, phenolic, hard wood, etc.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
I need help mounting a body to frame where it does not belong! (pics inside) fiscus Body - Exterior 9 11-27-2007 05:41 PM
How to on Body Off Build? joeford Hotrodding Basics 3 05-09-2006 07:29 PM
Body off question... joeford Hotrodding Basics 1 05-07-2006 07:26 PM
