Body cavity rust treatment - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 07:55 AM
I have an area under the tailgate of my Jeepster that is hard to access, but may collect water and cause rust. Does anyone know if a sealer of some sort can be sprayed (shutz gun maybe?) through a 2' or 3' piece of flexible tubing? Any other Ideas would be appreciated. I also thought of filling it with spray foam (messy) or seam sealer (hard to verify coverage).
Name:	RAPTOR LINER JAN16th 2011.jpg
Old 01-16-2011, 08:41 AM
hp246's Avatar
I would not fill it with foam. My understanding is the foam holds water, and makes the problem worse.
This might be an old wives tale, and am sure that someone here can say yeah or nay, but an old bodyman I knew did a ground up restoration on an old mustang. Us used to take old motor old and spray the frame and some internal parts of the body. He;d let it set for a day or two. Swore it prevent rust better than anything else.
Old 01-16-2011, 08:54 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i dont know anything about this stuff but it looks interesting and might work for you
http://www.eastwood.com/internal-fra...ay-nozzle.html
Old 01-16-2011, 11:06 PM
I've heard good things about the internal frame coating.
You could also talk to Krown or another rust-proofing company, they spray basically a commercial version of the eastwood stuff. They're usually relatively gentle on nice cars since all their customers are anal about the appearance of the cars.
If you're sure there isn't ALREADY significant rust, the used oil is a messy and environmentally nasty way to do it. I've done similar jobs with WD40, but never on cars I kept long enough to verify results.
Old 01-17-2011, 07:20 AM
malc's Avatar
Living At The Speed Of Life
There must be something similar to this, Waxoyl, in the States.
Old 01-17-2011, 09:31 AM
We do its called ziebart.
Old 02-08-2011, 01:13 AM
the caviety coating takes a special gun you can not spray it out of the schultz gun and get the results needed, The gun foggs the area getting coverage to everything. Cavity coating is very thin. A quart will do an entire car also Very good product
Old 04-27-2013, 04:31 PM
Pats55's Avatar
calcium sulfanate is good for tailgates ,doors and inner frame protection and for brake lines in corrosive environments
Old 04-28-2013, 12:27 AM
malc's Avatar
Original post.....01-16-2011, 02:55 PM......reckon itīs done.
Rust Treatment Products beertracker Body - Exterior 3 08-27-2010 02:41 PM
Rust treatment products ScotY Body - Exterior 21 11-22-2008 08:09 PM
Rust treatment and repair Riot Racing Body - Exterior 27 02-27-2007 01:12 PM
surface rust treatment coolP11 Body - Exterior 1 07-27-2004 11:25 PM
rust treatment? oldred Body - Exterior 6 02-18-2003 10:24 PM
