A-body crossmember 53 vs 55 inch - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2013, 08:39 PM
I am putting a 54 sedan delivery on a A-body chassis..the origanal crossmember (1 hump for single exhaust ) fit and aligned perfect with my new 700r-4 (B and M shift kit ) but I will be running headers w duels....sooooo I shopped on e-bay and some people have 55 inch crossmembers while mine is 53 and1/4 whats up w that I have no idea what year my frame is or what its origans are any Ideas ?
Old 01-30-2013, 04:37 AM
A-body cars with boxed frames (i.e., convertibles) use the shorter crossmember.
Old 04-02-2013, 07:33 PM
the Monte Carlo and Chevelle (I'm guessing the other a-bodies too) had a shorter cross member because the cross member was held at both ends by rubber isolators.
I got a longer cross member from a late 60's impala from a friend of mine and it bolted right into the frame w/o the isolators. (those isolators are near impossible to find and SUPER expensive if you do)
and it had the dual humps in it.. however.. the humps are closer to the center of the car, so a pre-fab exhaust kit might not fit well.
Give Konik's Klassik's a call. the guy who owns the place (Leo Konik) knows this stuff inside and out and can help you with new and/or used parts. (he's also a close personal friend of mine, he won't do you wrong)
www.koniksklassiks.com
Fox body Mustang rack on Fatman's MII crossmember SinistrV6 Suspension - Brakes - Steering 6 08-15-2011 08:33 AM
chevy G-body crossmember hause Transmission - Rearend 2 09-26-2006 07:04 AM
F-body transmission crossmember 428ho Transmission - Rearend 2 01-28-2005 07:52 PM
Crossmember is in the way of dual exhaust (G-Body) MuscleBlock81 Engine 14 01-30-2003 11:29 PM
G-Body Crossmember MI2600 Engine 6 07-22-2002 05:55 PM
