Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Body - Exterior, '32 Ford Roadster
Old 11-17-2006, 09:47 AM
dadsdream 32 dadsdream 32 is offline
If there is a VERY DETAILED manual available somewhere on how to assemble a '32 Ford Roadster I and many other first time builders could sure use it. I hate this "hit & miss, trial by error" build method. For instance, what is the best method of fastening the steel firewall to my Brookville body? If I include the rubber seal between the body cowl and firewall that seems to rule out welding. What do you experienced builders recommend?
