Thread Tools Search this Thread share on Facebook
  #1
Old 09-26-2011, 06:41 AM
SmileGuy49 SmileGuy49 is offline
body filler
I am looking to find a good body filler. I have worked with Bondo a few times in the past but was not too thrilled in the results. I have heard that there are newer products that are easier and smoother in the application process. I am also wanting to make sure it is not going to bleed through my paint. Do I have to go down to bare metal or can these products be used over existing paint? Thanks!
Register now (free) or login to remove ads
Old 09-26-2011, 07:06 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
I like Marson Platinum myself..there are others as well..
Sam
Old 09-26-2011, 07:27 PM
bighotroddin bighotroddin is offline
Evercoat Chrome-A-Lite is a good middle of the road filler. The better stuff is Evercoat Rage but it is over $50 a gallon.
The rage can be used over paint/epoxy if it is sanded with at least 80 grit. I have never had any bleed through or soaking caused by the filler. In any situation make sure it is featherd and finsished with 180 or finer before primer.
I never really had good luck with the Bondo brand stuff.
Old 09-26-2011, 08:03 PM
mitmaks's Avatar
mitmaks mitmaks is offline
Last journal entry: Grille
anything from Evercoat is a great product. More expensive ones just spread easier/smoother and sand little easier. A good trick is to mix a bit of glazing putty in your body filler and it'll spread out better and sand easier.
Old 09-30-2011, 06:24 PM
russ69coupe's Avatar
russ69coupe russ69coupe is offline
Last journal entry: ok, one step forward and about 15 back.
By "sand with at least 80 grit", do you mean 80 and grittier like 40, or 80 and smoother, like 120?
Russ
Old 09-30-2011, 06:57 PM
This being that most of the metal work is finsihed properly and that you are skim coating the surface with "bondo". You cant use any fibeglass reinforced filler over epoxy.
Old 10-01-2011, 08:47 PM
Lizer Lizer is offline
Another fan of Marson Platinum. It is the same thing as Rage, works just as well, and for half the price.
Old 10-02-2011, 10:18 PM
roger1's Avatar
roger1 roger1 is offline
I've never heard that before. Why do you say that?
Old 10-02-2011, 10:29 PM
tech69 tech69 is offline
Sam
Love that stuff. My only gripe is that any silky smooth bondo that's not evercoat takes a little longer to lose the tackiness but that's ok as long as you're patient enough to wait a little longer. Seems like that's the main difference between your rages/ extremes and Marson Platinum. I take that stuff over Evercoat any day due to price. I also tried Matrix platinum(or gold?) and it sanded really well. It's green. Sanded so nice I thought there's no way this stuff can take any impacts.
Old 10-06-2011, 06:54 AM
imperialman67 imperialman67 is offline
36-80
". You cant use any fiberglass reinforced filler over epoxy.
I have never heard this either?
Old 10-07-2011, 12:31 AM
It is only ment to be applied to metal that has been sanded with 36 grit.
Old 10-07-2011, 05:37 AM
shine's Avatar
shine shine is offline
Last journal entry: some progress
any filler can be applied to epoxy that is within the 7 day window . if past the adhesion window scuff with 80 grit.
and leave the 36 grit paper for the car lot hack jobs.
Old 10-07-2011, 07:05 PM
never, ever heard of that. In fact it doesn't even say it on my can of fiberglass filler.
What shine said.
Old 10-08-2011, 12:24 AM
What kind do you use?
I use Evercoat Everglass and it says to remove paint with a 36-80 grit disk prior to application.
Not sure how you have been taught but I have been in the auto body industry for 15 years and never seen anyone apply fiberglass filler over paint or epoxy primer.
Old 10-08-2011, 04:12 AM
shine's Avatar
any filler made can be applied to epoxy. it is the preferred way of doing it. yes you need to remove paint before using any filler but the method of filler over bare steel went out years ago.
epoxy gives better corrosion protection and adhesion.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "body filler"
ThreadThread StarterForumRepliesLast Post
Body Filler or ??beertrackerBody - Exterior110-25-2010 06:41 PM
Body filler?MrPhotographer06Body - Exterior201-23-2007 12:31 PM
body filleresahlinBody - Exterior1802-12-2006 02:59 PM
which body filler?flamedfordbroncoBody - Exterior912-21-2003 09:56 PM
Body fillerCustomFordBody - Exterior501-08-2003 07:50 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
