Body filler in a gun, anyone using it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2009, 11:22 AM
Any of you pros out there using this system?
http://carbodysupplies.com/shop/arti...ng-System.html
We had a demo yesterday and have the gun to try out. Looks VERY interesting.
Old 07-22-2009, 06:52 PM
Official Solventologist
I've seen it demo'd also Brian. It is a cool idea but if you do the math on the cost per gram of filler it is a whole lot more expensive than normal filler even if you take the waste filler in consideration. Your material bill will go up but it may pay for itself in labor savings. Let us know how it works out for you guys.
Old 07-23-2009, 01:37 PM
Well, the first impression is not good. The hardener had a clog in it. So to "bleed" it out you have to waste the filler!
http://i200.photobucket.com/albums/a...s/100_0173.jpg
Then, when it was being spread out I could see that it didn't looked mixed. Sure as poop stinks, it remained gummy in areas!
This is the part I don't like, you don't know how much hardener is being added! Yeah, the color, that's it. But the whole idea with this stuff is you go right to the spreader with it, well buckaroo it's too damn late, you are dispensing it!
So far, this sucker gets a big zero from me. I am not even sure I can ask the guys to use it anymore. They are gun shy, something about having to remove half cured filler from the car that they don't like.
Old 07-23-2009, 07:12 PM
Old Fool's Avatar
I can see the fail in the pic, that mixing tube is far to short to provide adequate mixing.
Take a look at a HILTI epoxy mixing gun, the mixing portion of the tube is over 6 inches long.
Old 07-23-2009, 09:45 PM
dinger's Avatar
I see the words 3M on it, that's a shocker. I would think they would be a bit more diligent in their research than this, what a disappointment.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 07-23-2009, 10:36 PM
It is much more than a mere "mixing tube" it's a little turbine! The friggin thing has this little propeller looking dude in the mixing tube that is spinning pretty fast and "chopping up" the filler and hardener!
I'll have to shoot a video of it to post. It is wild!
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Evercoat "kitty Hair" body filler chevymastermind Body - Exterior 12 05-11-2007 05:14 PM
Urethane primer and body filler Lator_Gator Body - Exterior 23 01-08-2007 02:15 PM
body filler esahlin Body - Exterior 18 02-12-2006 02:59 PM
Body Filler do's & don'ts Ron M Body - Exterior 2 09-07-2004 05:00 AM
