Body filler question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 06:46 PM
Hello everyone, I have just cut out and replaced a rear arch on my daily runner. I have painted the whole area with epoxy primer and skimmed the area with fiberglass paste. My next job is to skim the whole area with body filler. My question is this, is body filler paste impervious to rain/weather? I can only do so much at a time so can I fill and rub down and leave for a week, exposed to the elements, and repeat again next weekend? Or should I fill, rub down, and prime to seal one day and repeat over again in layers? This is the first attempt at any type of body work so any advice would be appreciated.
Many thanks
Paul
Old 01-22-2006, 07:43 PM
bodyfiller absorbs water. You should be okay inside out of the elements, exspecially since there is epoxy primer underneath it to seal the metal. But I would spray more epoxy over the filler before considering letting it see the elements. Epoxy primers take at least a few days to completely cure on most I have seen though. Thats why it is best to find another vehicle to run around in while you are doing bodywork. I suppose you could spray some Paint over it too, that has a realitively short cure time over the area to seal it also, then sand it all off when you are ready to finish and can let it sit longer. I'll be interested in what others have to say.
Old 01-22-2006, 09:54 PM
Paul, put a thin coat of primer over that filler then just sand it off when you get back to working on the car, you could just brush a thin temporary coat of epoxy on if you want to avoid the hassle of masking and spraygun cleaning. Unsanded fillers will shed water for quite awhile but most sanded fillers will soak up moisture like a sponge once they are cured.
Old 01-24-2006, 02:19 PM
Thank you both very much for your advise, looks like I will have to take a day off work!!!
body filler esahlin Body - Exterior 18 02-12-2006 03:59 PM
Using body filler on the underside of the floor pans NoClone Body - Exterior 11 01-12-2006 12:24 AM
brand of body filler, primer, paint to use? montea Body - Exterior 10 03-27-2005 12:01 AM
A Body mini tub question wally8 Suspension - Brakes - Steering 1 08-11-2004 06:09 AM
newbie body question matty Hotrodders' Lounge 17 08-20-2002 03:35 PM
