Thread Tools Search this Thread share on Facebook
  #1
Old 06-26-2011, 04:23 PM
Chevy 84 Chevy 84 is offline
Last journal entry: 69 Mustang
Body Filler/Rust
I have a question for all the body experts out there. I have old pickup that runs like a champ, and the interior was recently replaced, but the body is shot. Looking at it, you could'nt tell because it has a nice blue paint job on it. But once you get closer you see all the cracks from body filler and some areas of bubbled rust. My question is can I repair the body filler cracks, or would it be best to try and find a donor body. I'm not trying to get it show room ready, because I know it will never be a worth alot of money, but I want a nice looking truck.
Register now (free) or login to remove ads
Old 06-26-2011, 04:40 PM
poncho62's Avatar
poncho62 poncho62 is online now
Last journal entry: 51 Ford F1
Wiki Edits: 5
If you want it to look good for a few months, slap the filler to it......If you want something that lasts, get some new metal.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 06-26-2011, 05:59 PM
bighotroddin bighotroddin is offline
It all depends what the metal underneath looks like. Either the metal is rotton or the filler is cracking from a poor prep job.
If would just grind out the bad areas and see whats there.
Pics would help.
Old 06-27-2011, 06:41 AM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Old gunslinger
Wiki Edits: 11
The metal is cheap for these trucks its not worth doing filler work. Why spend ten hours fixing a 50.00 fender?? replacing everything will be cheaper in the long run and it'll look much better
Old 06-27-2011, 07:20 AM
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Well !!! Do you know for sure the body is bad ???? Or did someone do some bad body work .... I would strip the bad spot's and see really what's under there... Might just be a bad job... And a easy fix.. If it's real bad.. Then I would do like someone said..And just start replacing panels..
Old 06-27-2011, 11:24 AM
Old gunslinger
Wiki Edits: 11
Any of the old chevy trucks are worth fixin up,If you DIY...The after market parts fit pretty darn good and a good used bed 3-500.00 You can restore the truck very cheaply...and they sell fast....
I like working on them...
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Body Filler/Rust"
ThreadThread StarterForumRepliesLast Post
body filler after rust repairBadHabitSSBody - Exterior206-13-2009 07:53 PM
how: rust remove from a gas tank filler tubeglhxBody - Exterior205-07-2009 07:46 PM
Zinc body filler to patch rust??37year old kidHotrodders' Lounge602-17-2007 02:35 PM
Body filler?MrPhotographer06Body - Exterior201-23-2007 12:31 PM
Wheel Well Rust/Body Filler HelpOddballBody - Exterior1912-17-2004 03:33 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
