Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Body filler showing through epoxy primer
Old 05-08-2013, 05:55 PM
chief36chevy's Avatar
chief36chevy chief36chevy is offline
Last journal entry: Hood holder/horn mount
Ok I removed all the paint and filler on my 36 Chevy. I then applied 2 coats of epoxy primer. I then did the body work and filler (I used Rage). After sanding and cleaning with Eastwood’s PRE I applied another coat of epoxy primer. When it dried I noticed that I could see every spot of Rage filler.
My question is what is happening?
Could it be that the Rage is absorbing the epoxy like a sponge?
Would the epoxy then work as a sealer?
Should I shoot another coat of epoxy?
What should I do next?
