Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Body filler showing through epoxy primer
Old 05-08-2013, 08:13 PM
Lizer Lizer is offline
I've only ever used SPI's epoxy, but what you're describing is not unordinary. My car will look like a dairy cow after I seal over the top of my metal work with one coat of epoxy. Two coats of epoxy will cover the body filler. If you're sealing, shoot a coat of epoxy of your body filler spots, then shoot a reduced seal coat over the entire panel.
