Thread Tools Search this Thread share on Facebook
  #1
Old 08-25-2011, 07:40 AM
showtime1k showtime1k is offline
body filler showing through paint
areas where i have done body filler repair after painted the filler shows through the paint. anyone know how to prevent this action?
Register now (free) or login to remove ads
Old 08-25-2011, 07:46 AM
Old Fool Old Fool is offline
details would help
Old 08-25-2011, 07:53 AM
i sanded a ding on the door to bare metal, applied body filler, sanded smooth, primed, then painted. you can see an outline of where the repair was made(the body filler), but im sure it was smooth before i painted.
do i need a compatible primer with that paint?
or does it need a sealer in the repaired area?
or did i just use cheap primer?
everthing else came out very good except for the area of the body filler, its like an outline showing through the paint
Old 08-25-2011, 08:02 AM
MARTINSR MARTINSR is offline
Last classified ad: Fifties Chevy passenger...
About the only reasons this can happen is you are seeing an outline of the filler because it was over sanded leaving it lower than the metal. Or the primer over it wasn't applied properly or blocked properly. It could have been applied too wet so it shrunk up even after blocking it properly.
But I would put money on it that the filler was sanded too much leaving it lower than the metal. It was primed and blocked but the primer couldn't fill as much as needed being the filler was sanded so low.
These are classic mistakes and likely your problem.
Old 08-25-2011, 03:29 PM
milo's Avatar
milo milo is offline
point on positive
Pictures would be interesting ..
See if this read takes from the mystery..
http://www.a2zautoforums.com/showthread.php?t=936
The fix may not require stripping back through to the filler though will depend on more info/pics as above posts
Old 08-25-2011, 08:31 PM
Rag top bird's Avatar
Rag top bird Rag top bird is offline
Hot rods are still the king
I agree with the other guys when you primed you work did you notice a ring around the area the you repaired when you primed it in ?
Old 08-27-2011, 08:08 AM
Chevymon Chevymon is offline
You said you sanded the filler, but didn't mention sanding the primer or what type of primer was applied.
Old 08-30-2011, 07:50 AM
sorry, yeah i sanded the primer, it was 2 part high build sandable primer. only thing i can think of is the paint i bought he asked me if i wanted the good base or the cheaper one, i bought the cheaper base and the expensive clear.
Old 08-30-2011, 07:58 AM
Then I think you should reread the comments from Brian.
Old 08-30-2011, 03:34 PM
milo's Avatar
point on positive
Hangdude is lucky I'm not a mod here ..I would ban him so fast and then follow him around the net pointing out what a clown shoe he is for miss quoting my friends to get hits on his spam site
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "body filler showing through paint"
ThreadThread StarterForumRepliesLast Post
Filler showing after priming...blgliBody - Exterior305-12-2010 07:49 AM
Body filler?MrPhotographer06Body - Exterior201-23-2007 12:31 PM
brand of body filler, primer, paint to use?monteaBody - Exterior1003-26-2005 11:01 PM
body filler and black paintoldredBody - Exterior1312-18-2004 09:34 PM
Body fillerCustomFordBody - Exterior501-08-2003 07:50 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
