body filler on steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2012, 06:56 PM
Last journal entry: front fender and swing arm
I put some bondo body filler on a motorcycle tank to smooth out the raw metal and i dont know if its safe to just spray some 2k urathane primer over the bare metal and body filler or if i have to spray some sealer on it first.my plan was to spray the primer,let it sit a day or two,then scuff with 400,lay two different base colors and then clear.Will this work?
Old 05-30-2012, 07:01 PM
In a word, yes.
I am thinking your filler work will need some "surfacing" with 180 or so then go finer if you don't cut thru the primer. Or sand the whole thing with 180 and put another couple of coats of primer.
Old 05-31-2012, 06:51 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
On a tank I would just spray about 3 coats of SPI epoxy on it let it dry good and sand working up to 400 wet and paint.
First coat of primer over a combo of bare steel and body filler Migman Body - Exterior 3 03-24-2010 07:41 AM
body filler help please thanks yasmany Body - Exterior 3 11-17-2007 11:19 AM
Body filler? MrPhotographer06 Body - Exterior 2 01-23-2007 12:31 PM
Body filler JimmyL Body - Exterior 10 10-30-2004 12:10 PM
which body filler? flamedfordbronco Body - Exterior 9 12-21-2003 09:56 PM
