body to frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2007, 08:50 PM
blklar's Avatar
body to frame
Just about ready to bolt my 34 ford 3 window to the frame ,Do I need some kind of rubber between the frame and the body ?
Old 03-10-2007, 09:15 PM
DesertrusT's Avatar
Jailbar Revolutionary
Y not anyways
Yes and No.
You don't need to use any rubber, but then again why not use some anyway.
The rubber is dirt cheap, keeps vibrations down a little, keeps bolt down dents to a minimum.
You don't need em but why not fork out a few extra bones and put some on anyways.
Put it this way, it won't hurt and it's not something you can possibly regret.
Old 03-11-2007, 07:44 AM
302 Z28's Avatar
Depends, if your car is a glass body and you set it up without and you use it you will have re-assembly issues. I used some 1/16" neoprene rubber under my body. Some will say it prevents the body from squeaking on the frame. My take is if that is the case your body is not down tight enough on the frame. The original cars had some welting that was about 3/16" thick.
Vince
Old 03-11-2007, 11:25 AM
blklar's Avatar
body to frame
Thanks for the info Guys.
Old 03-11-2007, 12:21 PM
And if you do use anything like rubber be sure to use lock nuts. When the rubber compresses over time if you don't use a lock nut it will get loose.
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 02:39 PM
Body to frame washers, 55 Crown Vic John F Body - Exterior 3 01-16-2007 08:22 AM
body change to later frame streetrod936 Suspension - Brakes - Steering 11 12-15-2005 07:44 AM
What type of body??? with s10 frame 12second6 Body - Exterior 5 03-31-2004 05:32 PM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
