Body to frame washers, 55 Crown Vic - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 05:49 AM
I am in the process of replacing several mounting bolts on a 55 Crown Victoria which is nearing completion. I purchased the car with the understanding it was restored well but discovered upon very close inspection that it needed all new floor pans, and toe boards replaced. As I am doing this work, and have all the interior gutted, I want to replace the body bolts to frame, and also the special, recessed washers that go directly under the head of the body mount bolt.
I am seeking a source for these washers at this time. Any help would be appreciated. Thanks.
I would also like to know what would be a good, acceptable primer for these pans as I spot weld them into place before final finishing of the underside of the car, or if I should take the chance and use one of the more popular "No primer needed" black chassis paints. Thanks.
Old 01-16-2007, 05:53 AM
aka Duke of URL
I have a friend doing a 57 restoration that found his body mount hardware at DENNIS CARPENTER.
Old 01-16-2007, 06:22 AM
55 Crown Vic Body to frame washers
Thanks, I will check that out. I checked his catalog, didn't see anything but maybe I can call them direct. Appreciate your reply.
Old 01-16-2007, 08:22 AM
Irelands child's Avatar
Mac's seem to have a lot - try this (B7A-5001-C BODY TO FRAME WASHER) :
http://www.parts123.com/parts123/yb....ta~partsort~A2
OOPS WRONG YEAR - but this vendor site still may have what you need
Irelands child
torque specs for the body mount bolts on a 55 chevy Knightsgarage454 Engine 1 11-27-2004 11:38 AM
55 Chevy P/U Body Mount Question bluesman123 Body - Exterior 0 02-15-2004 07:21 PM
Crown Vic Hondakillr11 Hotrodders' Lounge 5 08-10-2003 11:33 PM
55 chevy frame in a sedan delivery? 55delivery Body - Exterior 2 03-16-2003 06:43 PM
31 ford 5 window coupe body and frame krzycat Body - Exterior 0 12-14-2002 07:00 AM
