body frozen out of position? (door seams) - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2014, 05:34 PM
The mobile view is crap
So about two weeks ago we had a pretty cold week or two here. One day driving down the road in my 01 f350 it sounded like my door was opened. When I stopped at a traffic light I opened and closed my door but it didn't help. When I got home i noticed that the top of the drivers side door and the top of the rear door (extended cab not crew cab) was touching and not allowing the front door to close all the way at the top. I picked up on both front and rear doors checking for pin wear but both were solid. I then thought well maybe I had a body mount fail and will check it out later. Well a couple of weeks have went by (truck is my weekend and recreation warrior) and I noticed today that I didn't hear the noise anymore and both doors looked like they were where they are supposed to be (looking at the door lines). Is it possible that there was ice froze between the body and frame and caused the body to be tweaked out of position? Has this happened to anyone else? I never looked at the body mounts either.
Old 01-19-2014, 06:09 PM
poncho62's Avatar
Wiki Edits: 5
I have had ice build up on the bottom door lip of my work van, causing the door not to close right, so I would think you could have had a similar situation.
Old 01-19-2014, 06:17 PM
its not just the door not closing right its the door seams were out of whack. The top back corner of the drivers side front door was actually overlapping the top front of the drivers side rear door.
Old 01-19-2014, 06:21 PM
sorry for the kindergarten drawing but I'm not sure if my recent explanation was making sense. A picture says a thousand words,right. The circled red part is where the doors were actually touching and the rest of the door was not touching each other.
Name:	ford doors.png
Old 01-19-2014, 06:26 PM
CraigK's Avatar
Last journal entry: For a change of pace
sometimes you just have to bring inside the garage and thaw it out
Old 01-20-2014, 08:20 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
I don't have a clue where the "middle of the mitten" is but if you've had the cold weather we've had, the seals get rather stiff. If you had that rear door open, it may have not shut properly from a stiff seal and held it forward at the top, causing the overlap. Did you notice if the gap at the rear of the back door was abnormally wide at the top ?
Old 01-20-2014, 08:37 PM
if you lived in Michigan you would know where the middle of the mitten is, lol. Yeah I don't remember looking to closely at the rear seam of the back door. If it happens again I will definitely investigate further and share my results. As of now everything seems to be home where it wants to be and working properly
Old 01-20-2014, 09:42 PM
I had to smile at 'middle of the mitten' because I live in MI.
Old 01-20-2014, 10:49 PM
I live in sunny California SF bay area so I sure as heck don't know crap about the REAL cold climates but I am a car guy and autobody repairman with decades of experience and I just can't believe that simply being cold is going to do anything like this.
I am eager to learn something new but I just can't accept this. A block of ice stuck in the door, yeah, that's like a rock for goodness sakes. But other than something wedged into the hinge area that is making the door sag be it a block of wood, a rock, or a chunk of hard ice, I can't imagine anything else happening to the body to do this. That trucks cab is EXTREMELY strong structurally, it just isn't going to get twisted like that without serious damage to the body or frame.
Old 01-21-2014, 07:08 AM
Wiki Edits: 27
thaw freeze cycle
We are having a little warmer weather now . only in the teens at night but sunny and clear in the day time and the sunshine will melt the snow and ice on the roof and the water runs down onto the weather strips. By evening it freezes the doors shut. It could be that the water collects in a weatherstrip pocket. , freezes, expands and a little more collects each day, building up an ice clob. . I hate all the newer cars that don't have drip rails. I have the speedster in the garage all apart taking up a lot of space, My step son has two cars in the carage, one his and one his sisters he is fixing, then with my 2 roll arounds, the lincoln tig255, the wife's car is being left out in the cold. We sometimes get freezing rain at night, ice build up everywhere
Old 01-21-2014, 07:32 AM
That makes a lot of sense.
Old 01-21-2014, 07:58 AM
being cold and frozen does a lot of weird things to cars. They make weird sounds, the radials get stiff, and my wife's car started to drive really bumpy. She kept asking me about it and I kept insisting that it was the cold and suspension being stiff and perhaps some ice buildup, but we finally were going to take it in to have the tires balanced. Well, we had a thaw and then the car was fine after that.
86 G Body rear control arm upper, how to remove frozen bolts? bubbahotep Suspension - Brakes - Steering 4 06-25-2012 05:54 PM
body position change davey nuts&bolts General Rodding Tech 3 03-25-2011 02:23 PM
Soldering Body Seams FiveFeezy Body - Exterior 26 03-16-2010 04:12 PM
body lead on seams ka24deroadster Body - Exterior 1 01-27-2009 08:32 AM
Which First: Door Jams Or Body ikeaguirre14 Body - Exterior 3 05-18-2005 09:47 AM
