Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - body holes on a 69 gmc truck
Old 01-14-2003, 07:12 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
Do not recommend leading. Weld them. You won't warp the sheet metal if you are carful and don't apply to much heat. Theres absolutly nothing wrong with using body filler as long as its used properly. Using it to fill hole isn't using it properly, it is only for final finishing and smoothing. Weld the trim holes shut by using a copper backing.
