Body Lean - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2003, 09:34 PM
DoubleVision's Avatar
Body Lean
I have a 1986 olds cutlass supreme, I recently added 2 inch drop front spindles, new shocks and tires all the way around, I also added new heavy duty front sway bar bushings and end links, the car sits lower on the passengers side, I`ve seen many cutlasses like this, but I haven`t figured out why yet, I`ve seen stock ones that sit like this and always on the passenger side, I measured the distance on fairly level ground, the passengers side sits about 1/4 inch lower, the rear sits at 3/4 inch lower, why do these cars do this? are the coil springs tired? it didn`t do this until I installed the drop spindles, but since i`ve seen many others like it, I know it`s not the spindles that caused it. when I`m driving it I can also tell it feels real soft on the passengers side, the control arm bushings are in good shape, and the car was aligned after I added the spindles, any solutions out there are real appreciated.
Old 07-10-2003, 01:14 PM
Will's41's Avatar
"it didn`t do this until I installed the drop spindles"
Are you sure both springs are fully seated in the lower control arm?
Old 07-10-2003, 02:23 PM
I`m positive they are, they never moved off the seated position when I did the swap. I know several people with cars identical to mine, after a few years they sat lower on the passengers side and no suspension mods had been done, I had the fear mine would do this after time and it drives me nuts with it sitting unlevel. I guess I`ll get back under it and go over everything again.
Old 07-10-2003, 03:35 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Just a thought, but is an '86 spring old enough for it to start sagging? I could see it being the passenger side since that's the one getting the most weight transfer. (can't think of anything else)
