Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - body line
Thread: body line
Old 10-07-2005, 09:16 PM
kenseth17 kenseth17 is offline
I do pretty much the same as bondo master does. Run your tape as bondo suggested and spread one half at a time. Also after your bodyfiller or filler primer is on, you can run your tape to the edge of the body line, and spray guide coat while the tape is still on, Then pull off and use the line of the guide coat to help you sand. Sand with a long board length wise up to the body line, then do the other half up to the line left by the guide coat. Then with following coats of primer you can see how straight its looking. You can prime just the bodyline until it looks nice and straight, then prime the rest of the panel once it is looks good.
