a-body mopar axle shafts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2007, 10:07 PM
Last journal entry: beginning of the 340 challenger
hi all im stumped on a problem...
my gf has a 68 dodge dart that im working on and I bought an "a-body" 8.75 rear end for it. Everythings fine but, the axle shafts are 5 on 4" bolt patterns if I am correct... now i have a 73 challenger and a 73 barracuda and both car's axle shaft bolt patterns are bigger; 5 on 4.50 bolt patterns im guessing (big bolt pattern im guessing)?
can i drill holes on the dart axle shafts to be that of the big bolt pattern wheels?
I got the idea from hot rod magazine. Check it out:
http://www.hotrod.com/projectbuild/1.../photo_02.html
Old 07-22-2007, 06:28 PM
IF ... there is enough metal ... sure no problem. Rodders have been changing wheel patterns for years.
Moser even offers that machine shop service ... reasonable cost also.
Old 07-22-2007, 06:50 PM
thanks
im workin on the mesurements right now so as to put the big bolt pattern on those little axles... anyone happen to know where i can get the bolt pattern layout with measurements and what not or do i have to continue doing it the long and hard way and measure everything???
i have a friend with a machine shop, and he says he'll do the machining but i need to get him the measurments.
and thanks again for letting me know it possible deuce.
Old 07-22-2007, 09:58 PM
A 5 on 4 inch pattern ... has a radius of 2 inches ...
A 5 on 4 and 1/2 inch pattern has a radius of 2.25 inches ... you would only need to move the studs out 1/4 of a inch. I would index the 5 studs half way between the other studs and out 1/4 of a inch.
Real easy to do with a divider head ... a good machine shop would have one. Index the studs 72 degrees each position.
Old 07-22-2007, 10:30 PM
what do you mean by index? off set them from the origionals??? and thanks
also how do i make sure i dont make the holes arn't too close or to far apart from each together.... probably a dumb question but, with my measurments my bolt holes are either too close or too far apart from each other
Old 07-22-2007, 10:36 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
That's a chuck type rear. So, the axle shaft has a big hole in the flange to get at the shaft retainer/bearing plate nuts. That hole is located between 2 studs.
I've heard of redilling those to the big pattern, but I don't recall how they got around that problem.
Old 07-22-2007, 11:25 PM
anyone know how many degrees each bolt hole is apart from one another from center to center?
Old 07-23-2007, 09:40 AM
35chev/302gmc's Avatar
360 deg /5 =72 deg
I did the same to my 8 3/4, if I where to do it again I would use after market
axles cut to b-body spec, then use avalible b-body backing plate and drums.
A-body brake drums are very hard to find and very pricey.
I paid $300.00 for a pair of new drums!!!!
1935 chevy,masters
Old 07-23-2007, 01:16 PM
i figured it out last night! thanks guys
about the drum thing... i read some where that since im using big bolt pattern, i could take the backing plate and drums off of a car that has the same pattern....
or why not just machine holes on the drum to match the new pattern?
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 03:39 PM
Handbuilt aluminum body ckucia Body - Exterior 25 07-18-2007 01:15 PM
Mopar "A" body question...... STATUTORY GRAPE Engine 18 12-07-2006 06:56 PM
32 Ford body, firewall and body bolts heyjude076 Body - Exterior 5 11-20-2006 06:57 AM
mopar body panels 71gtx Body - Exterior 2 09-10-2003 04:40 PM
