Body Mounts for 1935 to 1940 Ford car - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2009, 05:54 PM
32chevy vett's Avatar
32chevy vett
If some one out there had a 35 to 40 ford frame. They could take a photo of or make a drawing of the out side body mounts with the measurements and angles. Some one had done work on the frame and they are missing along with any clue of were they went. This would be a great help. Thank you
Old 02-15-2009, 09:54 PM
dinger's Avatar
tHE PICS IN MY JOURNAL ARE OF A 36 fORD COUPE FRAME. (oops, caps) Slightly modified with a new cross member and Mustang2 rack and pinion, the body mounts are the same.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 02-16-2009, 05:04 PM
32chevy vett
Body mounts for 1935 to 1940 ford car
Thanks Dinger Can you tell me if they are even with the top of the frame or are stepped down its hard to tell from the photos. If they are stepped down how much. Can you give me the distance between the two. You have the makings for a super street rod. that is nice. I saw the axle on your T WOW them are rare. I had one on my first rod in the 60s.
Old 02-17-2009, 07:45 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Here is a drawing from Wesott's-hope this helps-
Old 02-18-2009, 03:04 PM
32chevy vett
body mounts for 1935 to 1940 ford car
35WINDOW For some reason your drawing did not show up. But I took a look at your car. Very nice!
Old 02-18-2009, 03:31 PM
35WINDOW's Avatar
Thanks for the compliment!
try this-
http://www.wescottsauto.com/Tech/frame_specs.html
Old 02-19-2009, 09:06 AM
32chevy vett
35WINDOW That works. I printed a copy. Any one that has used this site can see way its #1 Thanks again.
Old 02-19-2009, 09:21 AM
35WINDOW's Avatar
You are so very welcome!
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
"Basics of Basics" Photographing your car. MARTINSR Hot Rod Art 89 03-31-2009 02:53 AM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Picking a color Wmarden Body - Exterior 6 10-23-2004 11:13 PM
