body mounts- rubber cushions or no? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2009, 06:30 PM
Wiki Edits: 31
I'm to the point, I'm going to start building my rat rod body. the way it will be done, is a lower 1"x1" square tubing framework bolted to the frame, and everything will be welded to that.. firewall is already done and has the 1"x1" tubing welded to it.. it will be bolted by drilling and tapping the frame for 3/8" bolts. but should I use rubber cushions in between? I'm planning on at least 8 body mounts on the 48x52" lower framework
Old 11-21-2009, 07:29 AM
cboy's Avatar
Last journal entry: Finished
I didn't use them on my roadster and did on my sedan delivery. I haven't had the sedan delivery running and on the road yet so I can't really tell you how much difference it makes. I think most folks will recommend including them and unless there is some overriding reason not to incorporate them into your design, I would use them.
BTW, if I understand your mounting method (the lower rail of the body skeleton sits right on top of the frame rail), you might want to consider using 1/4" - 1/2" rubber continuously under the entire length of your body skeleton - or wherever it comes in contact with your frame. This would give you very even support all the way around. I know on my roadster I had a slight bit of body flex when it was lowered onto the mounting points and the door jambs actually closed up about 1/8" - which created a rub when the doors were installed. (This is a potential problem with almost any roadster design since there is no support at the top of the door opening.) I had to jack up the body directly under the door jamb and weld in a new body mount at that position to remedy the situation. If you run a continuous hard rubber cushion between your body and your frame, you can hopefully avoid any problems like that.
BTW, I found a hard rubber material for this use at my local ACE hardware. It is 12" wide and sold by the foot off a roll. It cuts fairly well with a straightedge and a sharp exacto type knife. It's about 1/4" thick but you can glue and build up layers to suit your needs.
Always learning...and sharing what I've learned.
Old 11-21-2009, 10:16 AM
Wiki Edits: 31
the body will be 48" wide the entire lengh, and the frame is 26.5" wide so there will be a little overhang, but I'm going to run 2 inside suport rails overtop of the frame, and is where most of the body mounting will be.. it will be between 8 and 12 mount points... I'll get some of that hard rubber. if my local ACE hardware doesn't stock it, they'll order it for me... Thanks
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
30 A body Mounts Fastsx321 Body - Exterior 7 10-26-2007 01:04 PM
66 Tempest Body Mounts theuntouchables Body - Exterior 1 08-14-2007 05:38 PM
Solid body mounts ucmung Body - Exterior 2 05-31-2006 09:32 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
