Body off frame, what do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2011, 12:51 PM
Hey guys, im a little stuck here. I just got my frame powdercoated and looking good. So after i get all the chassis reassembled, i want to get the body painted. I cant do it myself, as its only a 2 car garage. The body also has some dents/rust in it. Do body and paint shops accept shells of cars? Is there a special place to get this done? Im looking to get the interior, exterior, and firewall/underside painted, basically a full body paint. Is this even possible or will i have to put the body back on the frame first? Thanks for the helP in advance!
Old 05-19-2011, 01:19 PM
boatbob2
body paint.
Hi,why not finish up the frame,to where it is a roller,roll it outside,cover it with a tarp get about 6 or 8 jackstands,put the body into the center of the garage,do the bodywork and paint ,then reassemble.there are plenty of painters here,that can help you out with painting info,,,
Old 05-19-2011, 01:48 PM
it can be done but transporting and putting it back on the frame involves risk of damage for a guy like you. i would want it on the frame when painted. why not paint the underside yourself, put it on the frame, then take it to the shop
Old 05-19-2011, 02:19 PM
Agreed.
You risk buckles and twists in the body with it off the frame;
I'd paint what you need to underneath, and re-mount the
body back on the frame. Much easier to work with a roller...
Old 05-20-2011, 05:33 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I painted a guys chev coupe with it off the frame. He had the body on a rotisserie and all the rest of parts just loose. Rotisserie made it easy to do body work and prime.
New frame old body justanotherjoe General Rodding Tech 1 03-16-2010 01:34 PM
2wd body on a 4wd frame??? d&c repairs it all General Rodding Tech 2 01-07-2009 09:03 PM
28 body doesn't seem to fit the frame oldguy829 Body - Exterior 17 11-28-2007 02:39 PM
body to frame blklar Body - Exterior 4 03-11-2007 12:21 PM
'74-'77 Corvette body on an A body frame blaileigh Suspension - Brakes - Steering 0 02-01-2003 07:32 PM
