Thread Tools Search this Thread share on Facebook
  #1
Old 11-16-2011, 04:35 PM
Jmccrack's Avatar
Jmccrack Jmccrack is offline
Body over shifter
I am building a 34 ford and am new to this. I have my motor and tranny on my chassis. I have just trial fit my Lokar shifter and am wondering , how do I fit the body over the shifter lever. If I take it off (which I can do) to try and put it back on with the body in place would be to say the least very tough. What am I missing?
Register now (free) or login to remove ads
Old 11-16-2011, 11:38 PM
406 bug's Avatar
406 bug 406 bug is offline
9.82 @ 139mph
Create a removable section of the "dog house" (trans. tunnel)
Old 11-17-2011, 12:20 AM
327NUT's Avatar
327NUT 327NUT is offline
............or with some very careful measuring you can cut a slot in the floor and fit the body over it. Use the body bolt holes in the chassis and the body to locate ......measure twice, thrice or more.....and cut once.
Old 11-22-2011, 11:52 AM
Jmccrack's Avatar
ReFab Tranny Tunnel
Thanks guys. I just recieved my 34 BeBop body. I cant belive how well it fits on my TCI chassis, they did a great job. I did not tell them I was using a Lokar shifter on top of my 700R4 tranny so...... I have to redo the tunnel. I see some good articals here on fabricating a fiberglass tunnel. Any words of wisdom? I guess what I need to do first is cut the old tunnel out untill the tranny fits well then build a mould over the 700R4 and fiberglass. I like the suggestion of making it removable, is that a good idea?
Old 11-22-2011, 11:58 AM
NEW INTERIORS NEW INTERIORS is offline
Set no limit's on yourself
Sometimes it's easier to put the shifter on then to take a chance with the body... It may seem easier to just life the body over it.. But sometimes it isn't... Now if you have a few guy's to help..It can been done..
Old 11-22-2011, 12:07 PM
The glass isn't hard at all.. Look in my Journal I built some fenders and it may give you some idea's..There's a lot of people here that would be glade to help anyway we can...
Old 11-22-2011, 01:27 PM
61modrod 61modrod is offline
Lost and out of my mind...
Cut a removeable plate in the tunnel.. easier and if you ever decide to remove or change you dont have to pull the body... My $.02
Old 11-22-2011, 02:34 PM
Irelands child Irelands child is online now
I have a removable floorboard in my steel 'A'. While you don't need as an extensive one, it sure makes life easier when you are working in that area (that console framework shown wasn't used). Lots of pretty careful measuring
Dave W
Old 11-22-2011, 04:53 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
If you have to remove portions of the fiberglass tunnel I'd not worry about repalcing it with glass. I'd make a nice cover out of 16 ga. steel and then glass some washer head nuts to the bottom side of the floor pan and bolt the new tunnel into them. This way you'll have a strong floor and removeable for trans service.
Old 11-23-2011, 10:08 AM
Jmccrack's Avatar
Thanks all. You have been a great help. If I could figure how to get some pics uploaded I would show you where I am.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Body over shifter"
ThreadThread StarterForumRepliesLast Post
LT1 balancer difference issues, F body to B bodyfast68Engine904-28-2011 02:29 AM
shifter tower, shifter rail and shift fork diagram needed!Chris KempTransmission - Rearend002-12-2009 05:59 PM
Will a Z gate shifter work with manual vlv body?lumberjacknoojTransmission - Rearend106-01-2007 08:43 PM
3rd Gen F-body rear discs on 65 A-body 12 bolt?smallblocker2Suspension - Brakes - Steering703-22-2006 12:51 AM
G-body consol/shifter swapolds79Interior112-01-2005 01:11 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
