Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - body panel alignment
Old 09-01-2003, 12:01 PM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
Start at the top of the fender, get it right with the door, then use shims at the bottom to make the body lines come together. Then go back and fine tune the alignment at the top, There is all different thickness of shims, just keep adjusting and shimming.
A little patience and it will all come together. HTH
Good Luck
Troy
