Body panel glue on aluminum?
Will glue for body panels work to attach two pieces of 1/8" aluminum flat stock to one another? If so, is the glue available at local parts stores or is it a special order type of thing? If not, is there some other bonding agent I can use? The pieces will not be under any stress or have to hole any weight...other than themselves.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
They do make a two part Epoxy.For bonding panels,Lets cut it up Knows,He said you will rip the metal,Before pulling it apart.Not sure what's it call,But if you pm him he will be glad to let you know.It has a special gun.
I think there one called or made by SEM,And another one called Norton Speed Grip.Just check to make sure I'm on the right page.
Hope this helps you. |
sanded with 80 grit, west system epoxy, held together for 5 years now......
| Holley Carbs with an Aluminum Body/ Fuel Bowl?? | acr | Engine | 1 | 11-03-2007 09:04 PM |
| Handbuilt aluminum body | ckucia | Body - Exterior | 25 | 07-18-2007 12:15 PM |
| wanted: an answer to a simple question | ikeaguirre14 | Body - Exterior | 4 | 05-15-2005 07:23 PM |
| my doors got stretched | nomad57ry | Body - Exterior | 17 | 12-02-2004 06:51 AM |
| body panel alignment | gmonkey | Body - Exterior | 5 | 09-01-2003 06:50 PM |
