body panel replacement crimping tool - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2005, 12:48 PM
38chevysedan's Avatar
Rest in peace, Deboard
Last journal entry: 38 chevy sedan
hi, my dad and i were wondering about a tool that we heard would make it easier to install body panels. We don't know what the name of this tool is, but it crimps the metal inward( kind of what a brake would do) and makes it easier to weld it back in place. Has anybody ever heard of this before? Any help would be greatly appreciated.
Old 03-26-2005, 12:57 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
IT'S called a 'flanger'. check harbor freight, eastwood, etc...
you can get an air powered one that also punches holes as well as flanges.
Old 03-26-2005, 08:44 PM
flanging tool
Is the panel you are replacing lapped from the factory?
If it isn't and you are making or using a patch panel you will be better off butt welding it. A lapped/flanged panel is very hard to work with a hammer and dolly. It will also become a good place for moisture to hide and start the rusting process all over again. Another problem will occur when using a lapped joint, they tend to appear in your paint job when the sun heats it up.
Keith Daleen
sedalia, Mo.
Old 03-07-2010, 06:30 PM
Keith Daleen
sedalia, Mo.
Man, am I unhappy to hear THAT!!!!! I just finished my body work incl flanged lap joints for partial quarter panel replacement. I'll seal the lap joint with seam sealer but never heard of the joint appearing in the sun. I made the joint under the body line so it wouldn't be so easy to see if it isn't perfect. Hope its not a problem.
Old 03-08-2010, 07:54 AM
Don't loose any sleep over it, it is likely not going to happen.
Old 03-08-2010, 10:34 AM
Shabby chic sheet metalshaper
Flanged, overlapped joints may be easier, but they are not better. As Keith mentioned, hard to work the metal afterwards. The flange can also change the contours of the metal if it is made on a curved section effectively shrinking the surface down. Add the weld shrinkage to that and it is a recipe for more filler than you might want to use.
John
Old 03-08-2010, 11:32 AM
I believe you that butt joints are best but would you say flanged joints might be a better choice for amateurs? This was my first attempt at MIG welding and panel replacement. Not sure I could have managed the precise cut and butt joint weld. Yep, it took some filler but I think it came out OK.
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
metalshaping and panel replacement '40 Willys roof Randy Ferguson Body - Exterior 18 11-26-2005 09:00 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Repair of large dents in roof? rlackey Body - Exterior 9 01-28-2005 10:36 PM
Best Body Panel Cutting Tool Ron M Body - Exterior 21 08-16-2004 08:57 AM
