Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Body part clearance on trunk lid to quarter panel
  #57 (permalink)
Old 04-13-2013, 09:24 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by kso View Post
Gaps sure have gotten better over time...still they did pretty good back when, considering what they had to work with and the factory situation. OK, what I really want to add to this thread is the following.
Here it is;...
When I was a kid;...
Dad said (so I know it must be true):
Panel gap is 5/32". Tolerance is, no visible variations along the gap upon a casual glance.
And, I would tig-weld the edge of the trunk lid (or door or whatever), moving fast and skipping around. Get the 1/16" steel rod hot and bird-doo-doo the stuff down for buildup, then grind it flat at the surface, then mark a line to grind to for the gap you want with masking tape and cut that, then radius edges like the folded sheet metal was and just make it look like it's supposed to. I've added a lot of metal that way sometimes.
BTW this is a hobbyist talking...not something I (or Dad) did for a living, but that's the knowledge.
This is something that does work...I speak from the experience of doing exactly what "kso" has suggested...This thread, permalink #15
"Thanks Brian...if only I would have taken the time re-read the thread....my bad. OK, if this isn't a super rare, Big Block or Z28 car...(Something that they didn't make to many of) then what you can do to enlarge a gap on your doors or your deck lid is to take a stainless steel welding rod...take off the coating and weld it to the lip or outside edge of the deck lid...these rods can be 1/8 of an inch wide when the coating is off and if you weld it onto both sides of the deck lid it will give you and extra 1/4 inch of deck lid to work with. After it's welded on, install the lid, adjusting it to give you your best fit. Grind away whatever you need to give you the gap you want, apply a little filler on the welds (both top and bottom of the deck lid), block, prime, block and paint.
If this is a super rare 70 Camaro, I would advise to have the quarters re-installed correctly to get your gaps. I've done this on several custom builds (usually pre-war cars), because they are customs it doesn't matter, gaps are what's more important than originality."
I hope this helps.
Ray
