body problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2004, 08:19 PM
streetandstereo's Avatar
body problem
i bought a 67 mustang fast back at this junkyard for 100 bucks
and i wana take the body off to remove the rust from the frame and powder coat can you guys tell me how to do this please?
hmm nobody wants to help thats cool
Old 08-10-2004, 09:36 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
Lets see where to begin.......body mounts, brake lines, all electrical connections, any hard lines that are bolted to the body anywhere, and BE SURE TO brace the body when you lift it(I assume yer not gonna take it off piece by piece) cause they will bend and you might as well throw it away then. good luck man.
Old 08-10-2004, 09:39 PM
New Member
no frame
Crawl underneath and check. I don't believe that the mustang has a frame. It uses uni-body construction. I have seen plans somewhere on the web where they made a framework of a couple of old rims and some iron to stand the car on it's side in order to work on the underside. My advice, good jackstands.
Old 08-10-2004, 10:27 PM
New Member
No removing the Mustang body from the frame. Its unibody, so either put it up on jackstands and work on it or buy a rotisserie so you can rotate it and work on it.
Jerry
My web page
Old 08-10-2004, 11:22 PM
thanx guys
can you give me a link to buy a rotisserie ive saved up about 3grand
Old 08-10-2004, 11:54 PM
mitmaks's Avatar
Last journal entry: Grille
build your own, will save you money
Old 08-11-2004, 06:12 AM
New Member
save your money
In the end you will be much better off investing your $3000 in a "sound" car. For only 100, I can't imagine that you got much of a deal. I have seen a lot of "starter" cars for decent prices.
