Body Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2004, 07:48 AM
PaulNJ53Ford's Avatar
Body Removal
ANY TIPS ON REMOVING BODY FROM 1953 2DOOR FORD? THE NOSE IS OFF . THE FRAME IS IN GOOD SHAPE JUST WANTED TO CLEAN IT UP THERE IS UNDERCOATING IN SPOTS
Old 10-16-2004, 09:41 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Body removal
I have always just found and removed all the fasteners and when I feel I am ready used my floor jack and some wood blocking to raise the body enough to get the frame out..
Look for e-brake cables and wiring harnesses as these can hang you up..If you miss something you will know very soon if something is still attached..
Use some blocking between the body and the jack so you do not dent in the floor panel..
Raise a bit and block and repeat the process at all four corners till the body is high enough..
Trick is to have enough 2x4 and 4x4 blocking on hand and have some extra jackstands as well..once the body is off it needs to be securely blocked so it does not fall..
Just my way of doing this one..
Old 10-17-2004, 06:25 PM
thanks for Info. I used some 4x4 and 2x8 planks and jack stands. and a house jack the body is off. now I have to get chassis ready for paint. I guess sand blasting is the best way.
Old 10-17-2004, 06:38 PM
Wiki Edits: 3
Cleaning chassis parts
Tip:
use a pressure washer to get the large gunk off..then I use my angle grinder with a wire wheel on all the areas that I can get to..
Save sandblast for the hard to get to spots...saves lots of sand this way..
Old 10-17-2004, 08:54 PM
Pony's Avatar
It's good to see another 53 on the board. Mines a 4 door Customline with a 351M, auto, 9" rear, and rectangular front frame section & 80 Chrysler torsion bar front end. ( pics in gallery)It had the V8 flathead/stick when I got it but it was very tired. I couldn't belive how nice and clean it was on the underside. Your lucky to find a nice frame with all the salt that been put on the roads over the years. What are your plans for it??
Old 10-18-2004, 05:58 PM
MY PLANS FOR MY CAR ARE GETTING THE FRAME CLEANED AND PAINTED . THEN INSTALLING 4 LINK SYSTEM IN REAR AND STREET ROD ENGINEERING SUBFRAME WITH AIR BAGS AND RACK AND PINION AND DISC BRAKES.ALSO 8.8 MARK VII REAR W/ DISC BRAKES. ENGINE 1990 5.0 MUSTANG WITH EFI. I CONVERTED TO 12 VOLT WIRE HARNESS. ALSO THINKING OF CHOPPING THE TOP. SHOULD KEEP ME BUSY FOR A WHILE
