-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Body Rotissarie Help (http://www.hotrodders.com/forum/body-rotissarie-help-157475.html)
mc73DD189 04-25-2009 06:34 PM
Has anyone ever built there own car body rotissarie? I know they can be expensive to buy and I've browsed some web sites that gave me some ideas but was wondering what ideas you guys had? If you could give me an idea how you made it and the cost if you don't mind. Anything would help. More info the better. I like to build one for a 73 Monte.
Thanks Andy
schnitz 04-25-2009 07:08 PM
Moving to the body forum to get better responses....
In a while, Chet.
mc73DD189 04-25-2009 07:16 PM
Saw some help from an old post
I saw one rotissarie from robss supersport site. Great info. :thumbup: Other examples would be appreciated.
schnitz 04-25-2009 08:57 PM
Rob is "the man" on his setup, isn't he? I don't have one (yet??) for my Monte either. Maybe willys36 or shine will post up a picture or two of the ones they have.
In a while, Chet.
327 / 350 hp 04-26-2009 08:15 AM
Thanks Andy
Hi Andy, a friend of mine made his for a 50 Ford car, it didn"t look difficult to do,he had small rubber tires on it to move on uneven ground .. I need one now so i will follow your post.. GOOD LUCK jim :welcome:
slingslingbinks 12-15-2010 06:56 PM
Autobody101.com has downloadable plans for a rotissarie. I followed them and with my own ideas made 2 rotissarie's. One for a 70 El Camino and the other for my 64 Mustang.
shine 12-15-2010 07:27 PM
1 Attachment(s)
i use this in my blasting business. it had to be adjustable to fit different cars. maybe 400 in it. very important............ buy good wheels. rubber ones flat spot .
slingslingbinks 12-15-2010 08:05 PM
1 Attachment(s)
I made my base from Kenworth truck frame rails and i can put an axle under 1 end and a toung in the other end and toe it to the media blaster if needed.
gow589 12-16-2010 06:47 PM
I have this one for sale if you ever get to southern In. You would have to modify the mount for your car.
http://www.rc-tech.net/pantera1/paint1/bot1.jpg
http://www.rc-tech.net/MGB/paint1/jam4.jpg
cacsmret 01-16-2011 09:24 AM
Rotissarie build thread
EZ over on Cadillacpower chronicled his rotissarie build; here is the link:
EZ builds a Rotissarie
Kevin
DadTruck 01-20-2011 08:29 AM
this is an interesting approach
http://slantsix.org/forum/viewtopic.php?t=35584
matts37chev 01-20-2011 08:35 AM
i have seen metal ones built like that :thumbup:
but i dont have enough room to roll my car around in the garage :D
Centerline 01-20-2011 09:12 AM
WOW! What an ingenious approach. Can't believe he only spent $30 on the lumber to build that. Beats the daylights out of spending a couple hundred in steel to build one yourself or $800+ to buy one. I may have to seriously consider building one of those for my Polara when I get done with the deuce.
http://i263.photobucket.com/albums/i...a/101_0534.jpg
http://i263.photobucket.com/albums/i...a/101_0536.jpg
http://i263.photobucket.com/albums/i...a/101_0529.jpg
http://i263.photobucket.com/albums/i...a/101_0530.jpg
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
timothale 01-20-2011 09:41 AM
rotissserie plans
We used plans down loaded for free from harwood, Google harwoodperformance rotisserie. and the resources info. all our steel was free from Demolition jobs either we did or from friends in the construction business. Just had to Buy 8 matching wheels from HF and hardware store bolts. We built a roll around gantry crane to lift the bodies up to attach and balance things so the body will spin easily.
mc73DD189 01-27-2013 12:37 PM
Haven't checked in for a while. I like the wood building approach. Never even thought of that. I'll look into it. Better that spending money on steel.
