Body Rotissarie Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2009, 07:34 PM
Has anyone ever built there own car body rotissarie? I know they can be expensive to buy and I've browsed some web sites that gave me some ideas but was wondering what ideas you guys had? If you could give me an idea how you made it and the cost if you don't mind. Anything would help. More info the better. I like to build one for a 73 Monte.
Thanks Andy
Old 04-25-2009, 08:08 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Moving to the body forum to get better responses....
In a while, Chet.
Old 04-25-2009, 08:16 PM
Saw some help from an old post
I saw one rotissarie from robss supersport site. Great info. Other examples would be appreciated.
Old 04-25-2009, 09:57 PM
schnitz's Avatar
Wiki Edits: 54
Rob is "the man" on his setup, isn't he? I don't have one (yet??) for my Monte either. Maybe willys36 or shine will post up a picture or two of the ones they have.
In a while, Chet.
Old 04-26-2009, 09:15 AM
327 / 350 hp's Avatar
Thanks Andy
Hi Andy, a friend of mine made his for a 50 Ford car, it didn"t look difficult to do,he had small rubber tires on it to move on uneven ground .. I need one now so i will follow your post.. GOOD LUCK jim
Old 12-15-2010, 07:56 PM
Autobody101.com has downloadable plans for a rotissarie. I followed them and with my own ideas made 2 rotissarie's. One for a 70 El Camino and the other for my 64 Mustang.
Old 12-15-2010, 08:27 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
i use this in my blasting business. it had to be adjustable to fit different cars. maybe 400 in it. very important............ buy good wheels. rubber ones flat spot .
Old 12-15-2010, 09:05 PM
I made my base from Kenworth truck frame rails and i can put an axle under 1 end and a toung in the other end and toe it to the media blaster if needed.
Old 12-16-2010, 07:47 PM
gow589's Avatar
the Clever Turn Signal
I have this one for sale if you ever get to southern In. You would have to modify the mount for your car.
Old 01-16-2011, 10:24 AM
cacsmret's Avatar
Last journal entry: Another year gone by...
Rotissarie build thread
EZ over on Cadillacpower chronicled his rotissarie build; here is the link:
EZ builds a Rotissarie
Kevin
The Following User Says Thank You to cacsmret For This Useful Post:
mc73DD189 (01-27-2013)
Old 01-20-2011, 09:29 AM
this is an interesting approach
http://slantsix.org/forum/viewtopic.php?t=35584
Old 01-20-2011, 09:35 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i have seen metal ones built like that
but i dont have enough room to roll my car around in the garage
Old 01-20-2011, 10:12 AM
Wiki Edits: 49
WOW! What an ingenious approach. Can't believe he only spent $30 on the lumber to build that. Beats the daylights out of spending a couple hundred in steel to build one yourself or $800+ to buy one. I may have to seriously consider building one of those for my Polara when I get done with the deuce.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 01-20-2011, 10:41 AM
Wiki Edits: 27
rotissserie plans
We used plans down loaded for free from harwood, Google harwoodperformance rotisserie. and the resources info. all our steel was free from Demolition jobs either we did or from friends in the construction business. Just had to Buy 8 matching wheels from HF and hardware store bolts. We built a roll around gantry crane to lift the bodies up to attach and balance things so the body will spin easily.
Old 01-27-2013, 01:37 PM
Haven't checked in for a while. I like the wood building approach. Never even thought of that. I'll look into it. Better that spending money on steel.
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 01:49 PM
HELP cracks on fiberglass body! Adamrmr Body - Exterior 22 04-23-2008 10:35 AM
I need help mounting a body to frame where it does not belong! (pics inside) fiscus Body - Exterior 9 11-27-2007 06:41 PM
How to on Body Off Build? joeford Hotrodding Basics 3 05-09-2006 08:29 PM
Body off question... joeford Hotrodding Basics 1 05-07-2006 08:26 PM
