Body swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2007, 08:41 PM
Body swap
Hi can any one tell me if the body (Cab and box) from a 1950 chev fit the frame of my project 1978 chev frame?
Kevin
Old 01-09-2007, 08:53 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Probably not without some alterations. An S-10 frame would probably work out better. No frame swap is a direct swap.
Old 01-09-2007, 08:59 PM
poncho62's Avatar
Wiki Edits: 5
I've seen a 50 on a later 4x4 frame, but it had to be lifted real high to clear the tires.
Old 01-09-2007, 10:33 PM
Swapping frames is 99% of the time a total loser. There are so many add on suspension componants to make your truck ride and drive better it just makes more sense to keep the original. It may be cheaper, but there is SOOOOOOO much time needed to modify EVERYTHING it just isn't worth it.
You will see people asking about frame swaps with the only thing on there mind is the wheel base. That is JUST the begining, and in fact the EASIEST thing to change. Heck, you could have a frame that had a foot longer wheel base that shortening it would be MUCH easier than using another frame that may need many more mods but the wheel base is correct.
The inner fenders and rad support would need SERIOUS mods to use just about any other frame as an example. The steering column location would need to be modified, the motor would be too far forword on the later truck so that would need to be changed. The frame on the 50 is VERY narrow, the later frame would likely get in the way of all the bottoms of the fenders and running board aprons.
All new running board brackets would need to fabbed. The gas tank location woudl likely need to be changed.
The list goes on and on.
Cam swap Questions wayfast77 Engine 3 10-18-2006 05:52 AM
Body mount question mrmagoo187 Body - Exterior 5 08-10-2005 11:51 PM
Body Shifted on Frame HeftyP General Rodding Tech 2 08-27-2004 08:43 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 03:15 PM
GMC 87 crew cab body swap edog1 Body - Exterior 4 08-18-2003 11:53 PM
