Body swap 98 s10 blazer to 98 sw10 frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2012, 07:59 PM
Body swap 98 s10 blazer to 98 s10 frame
Hey. I'm currently in need of a vehicle that has a larger seating capacity than my current single cab S10. I have someone willing to trade me a 98 S10 Blazer for my Mustang the Blazer engine and frame is all rusted out cause its sat for over 5 years. My Mustang is a project but cranks up and runs. I don't have the money to buy another vehicle so I was wondering if I could take the body of the 98 S10 Blazer and put on my 98 S10 frame and use the S10 engine. Can I actually do this or are the dimensions to different?
Old 08-25-2012, 10:08 PM
Wiki Edits: 31
dimensions are way off.
Old 08-26-2012, 10:00 AM
This sounds like a dead horse, there were too many options between these trucks. It would be a miracle if they match-up.
"the Blazer engine and frame is all rusted out cause its sat for over 5 years."
the body would have rusted off the Blazer before the frame would rust thru.
IF the Blazer is useable, all of the bolt-on accessories should swap over. Check out the brake and fuel lines and swap the engine/trans.
Good luck with it.
98 s10, 98 s10 blazer
chevy blazer frame the same as a 4x4 s10 pickup? bill 2163 Hotrodding Basics 3 01-13-2012 10:13 PM
trans swap out in 82 s10 blazer flippie35 Transmission - Rearend 1 07-03-2009 12:54 AM
Can I use a 1994 s10 blazer frame for my 1950 GMC? firefighter50 General Rodding Tech 6 10-10-2007 10:08 AM
engine swap in a s10 blazer bill bennett Introduce Yourself 4 05-12-2006 11:47 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 10:28 PM
