A-body swap to G-body? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2013, 12:22 PM
So i have a 87 Monte Carlo SS and im running a mild 454 sooo this 7.5 wont cut it. I read up and found that iceman has upper control arms for a 64-72 a-body to a 78-88 g-body. My question is are those the only things you need for the swap? Are the shocks and springs moved around or is it basiclly a straight bolt on once you hook up the upper control arms? Also will my stock lower arms work or do those need special swap one too?
Old 10-12-2013, 12:34 PM
This question comes up a lot. Aside from the control arm geometry differences, the A-body rear is 1.5" to 3" wider, depending on the year. Also, I don't know how things are where you live, but here on the east coast, desirable A-body axles sell for stupid money. By the way, do NOT be mislead by people selling "12 bolt" Cutlass/442 axles. These are NOT Chevy 12 bolt axles, despite the fact that the cover has 12 bolts. The ring gear is only an 8.5" held by ten bolts.
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
moving to suspension.... not sure why it was in transmission forum
Old 10-12-2013, 01:03 PM
Well that doesnt bother me at all, i actually was going to by spacers so the wheels would stick out a little so that eliminated something off my list lol. But other then getting those control arms do you know if the springs and shocks will be a direct bolt and placement?
Old 10-12-2013, 01:04 PM
Well i posted it up on here because it said transmission and rear end but thanks, Im new to the forum.
Old 10-12-2013, 02:25 PM
Banned
moser makes a all new 12 bolt for the g bodys
no mickey mouse links needed
Old 10-12-2013, 04:13 PM
LATECH's Avatar
Here is a guide I like to look at.
OLDSmobility.com - The 1967 Oldsmobile Cutlass and 442 Resource - A-Body Interchangeability
Lots of good info.
I like the Moser suggestion. You can get a bare housing for a 9 inch ford carrier for under a grand.
Strange also makes the same/similar thing
Fact is stranger than Fiction
Old 10-12-2013, 04:15 PM
LATECH's Avatar
More good stuff
Rear End Widths
Old 10-14-2013, 08:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Apologies , at the time I felt the question was more suspension related for bolting in different OEM rearend into your car. Not many OEM options for your application.
i would suggest a new thread in trans - rearend forum about a stronger replacement differential for your car. It has been discussed multiple times in the T & R forum.
I own a base level 1983 Monte Carlo, 305 , T-350. Been in the family for 20+ yrs. I like the car, even with 238k miles on it. It has been maintained well , it is not a hotrod, just a good looking , driving car
Old 10-14-2013, 09:28 PM
Proud LOSER
Is it going to see slicks? Or even a DR at a track?
If the answer is no then you can upgrade your 7.5 to handle a mild BBC on street tires....
With good parts they can take more then most people give them credit for,
Or swap in an 8.5 G-body rear and save your money.
Body swap help. "70" Cougar Body - Exterior 3 06-01-2008 11:21 AM
g-body to b-body rear end swap? 95coughnut Transmission - Rearend 5 04-25-2008 01:46 AM
GM A-body arms swap to B-body? hduff Suspension - Brakes - Steering 0 05-30-2007 09:12 PM
gm g-body rearend into a-body swap camaro guy Transmission - Rearend 1 03-28-2007 08:05 AM
g-body to a-body rear end swap? 85Sierra Transmission - Rearend 3 11-24-2005 01:34 AM
