Body swap help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 11:11 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
Body swap help.
Hey folks, Does anyone have any info on swapping My 79 regular cab F250 4x4 for a 79 F? Crew cab 2 wheel drive. Both have 4 speed's/351m400's. I plan on unbolting front clip, junking both box's and using my dog house cover. Unbolt the master from the booster. I'm not sure If the Crew cab (4door) use's the same 4 bolting locations as the regular cab of the same year. I'm also not sure which wiring harness i should use, reg. cab's or the crew cab's. For the rear mounts i'll be able to get. I've just never done this before basically, and not by myself. Any help would be greatly appreciated !
thanks again.
bill
ps. i've asked on fordtrucks.com and no response but i'll ask again.
Old 05-31-2008, 05:43 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Well I have never "swapped" that exact unit but If I have this right you are going from a reg cab to Ex cab?
OK
Providing the Mounts on the frame will line up here's how I would go about it
{in theory} [which means outta my head onto the puter screen hoping not to miss something important]
remove the front sheet metal fenders hood rad support.
remove the wiring harness undo @ fire wall
remove steering column or the shaft from the column to the box.
Undo brake lines from master leave master on cab.
undo all cables speedo ,E brake, shifting linkages,A/C lines. . .
Undo the cab mounts
lift cab off & reinstall in opposite.
Well I don't know if this helps hope it did.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 05-31-2008, 05:48 PM
poncho62's Avatar
Wiki Edits: 5
I take it you are not putting the box back on............
I believe that the 4x4 has a different floor pan than the 2 wheel drive....at least a Chevy does.........There may be some tranny/transfer case clearance problems.
Ontario Rodders
Old 06-01-2008, 11:21 AM
Thanks folks. I'm gonna go look at it again this week. ( crew cab) and probably buy it. I mean its only 650 bucks and a driver, so i can resell it if i have to.
bill
Pulling the body Rufus_2 Body - Exterior 8 01-15-2007 05:34 PM
Body mount question mrmagoo187 Body - Exterior 5 08-10-2005 10:51 PM
Body Shifted on Frame HeftyP General Rodding Tech 2 08-27-2004 07:43 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 02:15 PM
GMC 87 crew cab body swap edog1 Body - Exterior 4 08-18-2003 10:53 PM
