Body welding tips / tricks ? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-29-2009, 10:43 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Originally Posted by oldred
Whatever you grind with BE CAREFUL! It is very easy to warp sheetmetal with a grinder and more than one person has managed to do an excellent job of keeping the warpage down while welding only to warp the dickens out of it when grinding! I personally prefer those flap discs or a flexible sanding disc, I never use a stiff grinding wheel but then that's just me so use what works best for you.
I just did this myself. Actually had a nice repair going, had tacked in the patch with no warpage, skipped around and filled in the gaps evenly, it was turning out beautiful. Go back to clean up the welds to get that super slick finish and noticed my panel is all warped. Never gave a thought to the fact I was overheating the metal by grinding too much.
Still Learn'in
  #32 (permalink)
Old 06-29-2009, 12:24 PM
life is a temporary assignment
Still Learn'in
The grinding can sometimes be worst then the welding.. Both should be done with the same amount of care..
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
700R4 Why are the TCI manual valve body instructions so lousy? Bayley Transmission - Rearend 24 02-16-2009 12:49 PM
body tips ;)...ideas crazydude Body - Exterior 1 08-28-2006 07:46 PM
Body prep and tips for chevelle needed abe Body - Exterior 4 08-03-2003 10:15 AM
